  3. What is the correct way to make a cellview from DSPF file...
  • Views 12457
What is the correct way to make a cellview from DSPF file?
delgsy
delgsy over 4 years ago
The DSPF textfile is created through the extraction.
Then, I created the DSPF cellview and a text editor is opened.
I tried using ctrl+a ctrl+c ctrl+v but it does not work.
Trying to copy some part of the text works, though.
So, it does not work maybe due to the fact that the file is large.
  • delgsy
    I got a solution from here.
    I wonder if there is a less manual way than this and copying the text.
    Andrew Beckett over 4 years ago in reply to delgsy
    You can use the command line "cdsTextTo5x" to import it into the cellView. Type this with no arguments and it will give you help - in particular you'd need the "-lang dspf" argument.
