  3. Pin type options in Cadence Virtuoso
  • Replies 8
  • Subscribers 136
  • Views 25020
Senan
Senan over 4 years ago
I have a question about the options for creating pins in Cadence virtuoso, there are many types to select, for example, power, ground, signal, clock ..etc.
Do they have physical meaning during the circuit simulation or real chip fabrication after exporting the gds file?
I have realized lately that I am using "signal" type even for creating the vdd! and the gnd! global and the clock pins in my design.
Thank you
Regards
    ShawnLogan over 4 years ago +1
    Dear Senan, Well, I am sure my answer is very incomplete and may be totally obvious to you, but the different signal types allow for schematic checking as a means of avoiding future schematic hierarchy…
    Andrew Beckett over 4 years ago in reply to ShawnLogan +1
    Senan said: Do they have physical meaning during the circuit simulation or real chip fabrication after exporting the gds file? No. They are used for tools to check various things (such as suggested above…
    ShawnLogan over 4 years ago in reply to Andrew Beckett +1
    Dear Andrew, Once again, I thank you for your added comments and insight! I knew my answer was not complete and hence not comprehensive! Shawn
    Dear Senan,
    Well, I am sure my answer is very incomplete and may be totally obvious to you, but the different signal types allow for schematic checking as a means of avoiding future schematic hierarchy or simulation errors. For example, Virtuoso can provide various warnings when you perform a schematic or symbol "Check and Save" operation to allow you to catch potential errors in a schematic or symbol view.
    The following article details how you might customize the various checks that are performed during a "Check and Save" operation and includes some relating to signal pin types.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009F6E2EAK&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed
    For example, a common warnings includes checking if there are more than one pins defined as an output connected to the same net (i.e., two of more pin signals defined as "outputs"). A second example often caught is a signal pin whose name falls into one of those names categorized as a "power" or ground". The Check and Save operation can generate a warning as Virtuoso interprets the pin as a "power" or "ground" pin and sees the pin as type "signal".
    Does this help at all Senan?
    Shawn
    No. They are used for tools to check various things (such as  suggested above) and to aid automated processes (e.g. routing). They do not affect the stream (GDS) file, and have no physical meaning.
    Dear Andrew,
    Shawn
  • Senan
    Senan over 4 years ago in reply to ShawnLogan
    Dear ShawnLogan and Andrew
    Thank you very much for your reply,
    you made it crystal clear and have no further comment on this topic
    I am grateful for you both
    Best Regards
  • Senan
    Dear Shawn,
    It is about your answer you put on the edaboard about me,
    i put that question beofre i present it here, and some times i do on both forums
    However your answer here was sufficient. Neverthelss I use other ID on that forum and you indeed have exposed my private information from this forum to that forum out of my wish, you see I use different name there.
    I would like to ask you to remove your reply on that forum as soon as you can please. and I do appreciate your help
    Regards
    Andrew Beckett over 4 years ago in reply to Senan
    I won't speak for Shawn, but I think you're being unrealistic here. If you post the same question in more than one place, then it's perfectly reasonable for somebody to reference the answer in the other place to avoid duplication of work from people who reply. I do the same thing with the Designers' Guide (I don't participate however on edaboard because I don't have the bandwidth for yet another forum, the signal-to-noise isn't high enough there and I don't know enough about who runs it).
    Given that your identity is obscured in both forums, I don't really see how your "private information" is exposed. By linking the threads anyone is very likely to come to the same conclusion that the two questions were posted by the same individual - and so that's what's going to happen if you post the same question with identical wording in two places.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew
    But he doesn't need to emphasize!!!, not necessary to highlight my name this way,
    the more realistic is to speak generally because it is more realistic to notice I am using a different name, that is why i see myself as more logical and realistic in this manner.. what the reader do there to tell him my name??, most of the people are interested in getting answers to their problems only and if they came by themselves here then let them know,
    any way I asked him to delete it nothing more, you are talking to me like I went to curt :D :))
    thank you Andrew, you and Shawen always help me, so this issue is not a big problem
    Regards
    I think you're reading far too much into this. It's not emphasising anything - merely checking if indeed it was you. It wouldn't be the first time that we see the exact same question from different people, sometimes because they have been asked this as part of some university course - and they are unaware of the other question. Either way, he was asking you - I saw no emphasis and I cannot understand why you are getting bothered by this.
    No idea what "went to curt" means, but regardless of this, it's a bit odd to be asking in the Cadence Community Forums about some concern you have about a post in a completely different forum. If you have a concern about a post you want deleted, ask it there, not here.
