  3. Parallel routing from bus on the layout
  • Views 14261
Senan
Senan over 4 years ago
Hello
I am using Cadence Virtuoso version IC6.1.8-64b.500.6.
I want to rout parallel wires from a group of bus pins on the layout. I tried to select those pins but when I do the Creat > wire > bus the cadence creates the bus but not exactly an extension of the pin positions that I want to extend.
Thank you for your help in advance
Regards
    I have no idea what "but not exactly an extension of the pin positions" means. Maybe a picture would help? Andrew
    Andrew Beckett over 4 years ago in reply to Senan +1
    Rather than pre-selecting the vertices you want to extend, use Create->Wire->Bus with nothing selected, and then do an area select of the vertices you wish to start routing from. That will do what you…
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    I have attached you an image, assume I want to route these connections parallelly, how can I make it
    Regards
    Rather than pre-selecting the vertices you want to extend, use Create->Wire->Bus with nothing selected, and then do an area select of the vertices you wish to start routing from. That will do what you want.
  • Senan
    Thank you very much  Andrew,
    it is a perfect solution, I do appreciate your help
    Best Regards
