  3. Instance within a cell as parameter
  • Views 11531
stephbur
stephbur over 4 years ago
I have a hard time describing what I want in few words, which also makes it very hard to search for it.
I have a base-cell that already contains a number of subcells. To this cell I also need to add a preamplifier, which I have several versions of.
Currently I manually create many new cells, with base-cell and preamp1, base-cell and preamp2, ... and so on.
What I would like is to have a single instance that I can place sometimes with preamp1, sometimes with preamp2 etc., passing the desired preamp as a parameter.
Is functionality like that available, perhaps using SKILL?
I am thankful for any pointers where to look for or what SKILL functions I should look into.
    One approach would be using a hierarchical pcell, but before suggesting that I'd like to understand whether this is for schematics or layout? If it's for schematics, there may be an easier way that doesn't involve needing to write SKILL code or use a PCell development tool such as PCell Designer.
  • stephbur
    stephbur over 4 years ago in reply to Andrew Beckett
    It would be for both schematics and layout. The cells themselvesdon't have to parametrizable though, only which instance is placed needs to be parameterized.
  • stephbur
    Hi Andrew
    For the layout I got an easy solution (see below).  What kind of functions would I need to use to make something similar for schematic?
    And another thing that bothers me: Like this the preamp is "outside/on top" of the base cell, while semantically it belongs to  an analog chain within the base cell. Is it possible and/or advidsable to have hybrid cells? I.e. Cells that are partially SKILL code and partially "traditional"  manual layout?
    pcDefinePCell(
    list(ddGetObj("mylib") "mycell" "layout")
    ((preamp_id "int" 1))
    let( ()
    tfId = techGetTechFile(ddGetObj("mytechnology"))
    base = dbOpenCellViewByType("motic_puc" "base" "layout")
    pcInstp = dbCreateParamInst(pcCellView base "base" (0:0) "R0")
    case( preamp_id
    (1
    preamp = dbOpenCellViewByType("r4s" "preamp_a" "layout")
    pcInstp = dbCreateParamInst(pcCellView preamp "preamp" (0:0) "R0")
    (2
    preamp = dbOpenCellViewByType("r4s" "preamp_b" "layout")
    (3
    preamp = dbOpenCellViewByType("r4s" "preamp_c" "layout")
    );let
    );Define PCell
