  3. How to know ADE runICRP files come from which library and...
  • Views 12453
How to know ADE runICRP files come from which library and cell view when the run status is pending?
JMTKRex
JMTKRex over 4 years ago
In ADE ICRP mode
When I click the green run button, ADE will create a runICRP file and start to run this file.
./.tmp_user/.cmddir0/runICRP6
if the runICRP file is pending status not start to run, how to know the file is created by which library and cell view?
the file only has the below information:
#!/bin/sh
cd /home/user/cds_case/test01
virtuoso -noautostart -mpssession "virtuoso85958" -mpshost "aa-sim-203" -davinciService "DaVinciService_85958_1648583981" -log '/home/user/cds_case/test01/logs_user/logs0/Job32.log' -licenseLockFileName '/home/user/cds_case/test01/.tmp_user/.aa-sim-203_85958' -interactiveA -interactiveE -interactiveRTT -axlChildIdFlag 32 1>/dev/null 2>/dev/null
exit $?
because it's pending status so the Job32.log does not start to create.
    I don't think you can. You can look in the ADE windows open and hover over the little terminal icon in the Run Summary assistant and one will state that it's Job 32, but I don't think there's any public way to link the two.
    If you're trying to identify problems during starting of the jobs, then one thing that might help is to try setting the showJobStderr and showJobStdout cdsenv vars (use Options->Cdsenv editor in the CIW and search for "showJob"). However, that relies on your job submission command printing something as the job is submitted (you didn't say why you need this, although I'm guessing it might possibly be related to case 46607263 - was that you?)
  • JMTKRex
    JMTKRex over 4 years ago in reply to Andrew Beckett
    case 46607263 is not mine, we want to add some process before the ICRP job starts to run, so need to know the ICRP comes from where.
    Andrew Beckett over 4 years ago in reply to JMTKRex
    OK, it was just a guess as it was very recent and sounded related and some of the characters in your user name suggested to me that you might be from the same company (again, just a guess). I think it's best you contact customer support, as maybe what you want to do can be achieved a different way - we'll probably need some info on what it is you're trying to do before the ICRP job starts.
  • JMTKRex
    We want to automatic and dynamic add some LSF options according to the cell view name
    ShawnLogan over 4 years ago in reply to JMTKRex
    Dear JMTKRex,
    I am not sure if your need to dynamically add LSF options according to your cell name are related to the LSF resource requirements for the job. However, if they are, have you seen the following Cadence On-line support article detailing how the LSF command resources can be varied based on specte's estimate of its memory and recommended number of CPU for that job?
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009Mom9UAC&pageName=ArticleContent
    This may not be what you were hoping for, but thought I should at least pass it on JMTKRex!
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    On similar lines to what Shawn was suggesting, I was thinking that a better approach might be to have a trigger (registered with axlSessionConnect, or maybe triggered by axlSessionRegisterCreationCallback). It might be the postCreateSessionDB or postLoadMainSetupDB signal (axlGetSignalList is the thing to look at) which then creates a per maestro cellView job-policy. Some people do this with a preRun trigger, but the downside is that if you end up changing the job policy at pre-run time it can restart the jobs and hence lose the benefit of any linger time.
    This would be a better approach than having your submission command trying to infer stuff about the cellVIew based on the script it's being asked to submit, especially as there's no way of doing that.
