  3. steadyratio impact on pss
  • Subscribers 136
  • Views 16219
sjwprcker
sjwprcker over 4 years ago
Since I need to handle some pss convergence issue, i try to define steadyratio = 1.0 to converge the pss.
But I can't figure out the concrete impact of such a parameter on pss simulation. I can imagine the pss accuracy is relaxed, but i want to evaluate if such relax is acceptable.
I have read the chapter in "Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer User Guide", but still not clear.
BR
    Generally speaking I would leave steadyratio alone. I rarely use it to aid convergence problems. In general the convergence criteria (which is covered in that manual, but will be covered in more detail in the Spectre RF documentation from the SPECTRE release) is the same as the normal convergence criteria the local truncation error at each tilmestep, but multiplied by the steadyratio. It's tighter because you're trying to ensure that the first and last time point are essentially the same (with a small error). With it set at 1 then the criteria is the same as at each timestep - determining how close the solved value is to the predicted value. In this case we know that the first and last values should be the same for it to be periodic (and we already simulated the first time point, so it's not a prediction), so it's reasonable that it should be tighter.
    Increasing the value could lead to it incorrectly identifying the circuit as settled when it hasn't actually settled - remember that the periodic steady state is trying to find the settled periodic behaviour of the circuit (for both shooting and harmonic balance).
    I suggest you take a look at <SPECTREinstDir>/doc/spectreRFTheory/spectreRFTheory.pdf for more detail (searching for streadyratio in this document gives the equations used). That's got more detail than the document you're looking at.
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Andrew Beckett
    If you decide to increase steadyratio, I suggest that you only increase it as much as needed. Find the lowest value of the "Conv norm" in the spectre.out log file and multiply steadyratio by just a little more than this value. Do not use this method if the resulting steadyratio value would be larger than 1.
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    I just copy the description from spectreRFTheory.pdf here:
    The steadyratio parameter specifies the maximum allowed mismatch between node voltages or current branches from the beginning of the steady-state period to its end. The steadyratio value is multiplied by the lteratio and reltol parameter values to determine the convergence criterion.
    So can i say, larger steadyratio relax (but not tight) convergence request for PSS?
    And, i also find that for different errpreset, steadyratio is different also.
    E.g., for shooting PSS
    Steadyratio = 0.001 @ liberal
    Steadyratio = 0.001 @ moderate
    Steadyratio = 0.01 @ conservative
    From such a relationship, it seems the larger steadyratio, means better accuracy and tighter the mismatch?
    Is there any contradiction in the definition?
    BR
    Andrew Beckett over 4 years ago in reply to sjwprcker
    There's no contradiction, because reltol is tighter for conservative. The tighter reltol cancels out the looser steadyratio. However, the tighter reltol will also impact the accuracy of the iterative solver as well as the local truncation error, and so overall it will end up more accurate (also every point in the period ends up being more accurate, not just the end points).
    In the early days of Spectre RF, steadyratio used to be might tighter for conservative which resulted in it being extremely difficult to converge; the choices have been stable for many years now and were the basis of many tests on lots of different circuits.
  • sjwprcker
    Thanks Andrew, so i can say larger Steadyratio means relaxing convergence of PSS, right (assume other parameters are fixed) ?
    Yes.
