  3. CDF Edit feature disappear
  • Views 10310
sjwprcker
sjwprcker over 4 years ago
Hi Sir,
I try to edit the termOrder in CDF/Simulation Information tab. It works but the new feature disappear when i restart cadence.
There is a data.dm file checked in for the target cell.
Does it mean cadence reload the info in data.dm every time after reboot, so that CDF is overwritten?
How i can change permanently termOder through only editing CDF, but not recreate the symbol again (since the cell is from 3rd part, not able to be checked out).
BR
    You need to change the CDF Layer to "Base" on the Tools->CDF->Edit form. Otherwise it is only changed in memory.
