  3. How do I to speicfy a list of external parameters and pass...
  • Subscribers 136
  • Views 12436
How do I to speicfy a list of external parameters and pass it to ADE L for simulations?
john611
john611 over 4 years ago
I have several dozen parameters in my simulation netlist that need to be defined, mainly resistors and capacitors i.e. C0=, C1=, C3= ... etc. and R0=, R1=, R2= ...
I want to define these parameters in an external file and link it to the ADE L GUI.
So far the GUI suggests me to type those values beside each parameter, when I try to "netlist and simulate". I have too many parameters to type in the GUI.
I want to define the parameters in an external file, andt then link the file to my simulations. How do I do it?
    Andrew Beckett over 4 years ago in reply to drdanmc +1
    Just tested this, and it works OK provided you go to Simulation->Options->Analog and on the Check tab change redefinedparams to ignore or warning . What happens is that ADE discovers the variables, but…
  • drdanmc
    drdanmc over 4 years ago
    I don't know how to directly point at a file but something like the following SKILL code lets you add design variables to the ADE-L GUI:
    session_id = asiGetSession(hiGetCurrentWindow())
    old_variables = asiGetDesignVarList(session_id) ;; if you want the existing variables
    ;; to set variables, create a list of name, value pairs like
    new_variables = list( list("MYVAR1" "3.2") list("MYVAR2" "123"))
    ;; and then
    asiSetDesignVarList(session_id new_variables)
    you could write SKILL code that access the existing list, updates/appends to it from the contents of a file, and then writes it back to the session.  If you or a coworker are proficient in SKILL then maybe the above small example will point you in the right direction or at least the right section of the manuals.
    -Dan
    In addition to Dan's suggestion, you could probably also just have an include file (with a .scs suffix) that you include via Setup->Model Libraries with:
    parameters C0=1p C1=2p C2=0.5p
    although the main challenge might be if ADE auto-discovers the missing variables and adds them in ADE too. I didn't check to see how this behaves in ADE L (and I can't remember off the top of my head).
  • drdanmc
    drdanmc over 4 years ago in reply to Andrew Beckett
    I'm pretty sure during netlisting the missing variables are identified and put into the GUI with blank values.  I don't quite recall what ends up in the netlist at that point.
    Just tested this, and it works OK provided you go to Simulation->Options->Analog and on the Check tab change redefinedparams to ignore or warning. What happens is that ADE discovers the variables, but it's netlisted as:
    parameters C0 C1 C2 C3
    include "extra.scs"
    (where extra.scs had my hand-written parameters statement). Because the extra.scs is included after the parameter definitions from ADE, then the value specified in the extra.scs wins (even if a value had been set in ADE).
