  3. ADE Explorer - Extracted DSPF Netlist - Probing Transient...
  • Views 4864
ADE Explorer - Extracted DSPF Netlist - Probing Transient Current
life
life over 4 years ago
In prelayout test bench, I am able to "save" and "probe" current terminals directly from a junction or port. For example, after running a transient simulation, I can do Results-->Direct Plot-->Transient Signal and plot the transient currently directly.
However, when I use a DSPF extracted netlist, I am unable to probe currents anymore.
Under "OUTPUTS --> SAVE ALL --> Save By Subckt" I have the modules for V, I, Pwr, and Ports saved with 3 levels of hierarchy but I am still unable to probe the current.
What is the best way to probe current using extracted netlist?
I am using Cadence Version  20.1 64bit, thank you in advance
    ShawnLogan over 4 years ago
    Dear life,
    Did you happen to read or try the exercises in the Rapid Adoption Kit (RAK) entitled "Working with DSPF Files in Post-Layout Flows in Virtuoso ADE Explorer and Assembler" at URL:
    https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000009MqziUAC&pageName=ArticleContent&attachId=0693w0000065R0OAAU&sq=null&caseSessionKey=null
    This note details methodologies to use your pre-layout net syntax when re-simulating a netlist where the net is embedded in a DSPF include file. In particular, please refer to "Module 1: Mapping DSPF File and Schematic Syntax"
    Does this help life?
    Shawn
