  3. PVS requires pin Label to pass the LVS
  • Views 11787
Senan
Senan over 4 years ago
I am newly shifted to the PVS tools of Cadence,  and I used to have Assura.
I am facing an issue of running the LVS from the PVS, that is it reuires me to add labels for my pins, otherwise, a mismatching will give. this situation never faced when I dealt with Assura before. is there any way to switch off this check,
I am using PVS version 19.10
Thank you in advance
Regards
    You were probably using Assura based on the OpenAccess database rather than stream (GDS) format. PVS really needs the labels to identify pins. For more information see Understanding how PVS processes text / labels / pins and FAQs
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you very much for your help, that was a useful solution and covered my inquiry
    Best Regards
