  3. How to change VIVA zoom time-axis (Shift+ mouse scroll)
  • Views 14937
Nader Fathy
Nader Fathy over 4 years ago
I am using Virtuoso IC6.1.8-64b.500.24, and Spectre 21.1.0.334.isr6. Whenever I plot any waveform on VIVA and try to zoom-in the time-axis using (shift+mouse scroll) it doesn't do anything. However, ctrl+mouse scroll zooms-in vertically.
It seems like its an issue from a 3rd party tool I am using to remotely access Linux server, whenever I login from Windows the zoom works fine, but when I login from Macbook (shift+mouse scroll) doesn't work.
Is there a way to change this shortcut?
Many thanks in advance,
Nader Fathy
    Hi Nader. I don't think it's possible to change this as a bindkey setting, unfortunately. Andrew
    ShawnLogan over 4 years ago +1
    Hi Nader and Andrew, Nader Fathy said: I am using Virtuoso IC6.1.8-64b.500.24, and Spectre 21.1.0.334.isr6. Whenever I plot any waveform on VIVA and try to zoom-in the time-axis using (shift+mouse scroll…
    ShawnLogan over 4 years ago in reply to Nader Fathy +1
    Hi Nader, Nader Fathy said: I tried your suggestion but still I am not able to control the X-Zoom in Viva (Please see the attached screenshot). Rats! However, I must thank you for letting me know…
    Hi Nader.
    I also use a Mac with a VDI to access a Linux server (mac-mini running macOS Mojave - 10.14.6) that runs Cadence tools.  I have used a number of VDI and, after much experimentation with other VDI, find the NoMachine VDI (https://www.nomachine.com) to provide the most robust connection and have used in for years on my Mac and now on Windows. There is also a version for iOS.
    With ViVA, I am able to use the bindkey to control the X-zoom using the mouse to highlight the region I want to expand with the shift-Control key combination. I show the key combination in Figure 1 from the Keyboard viewer. Nader, you might use your keyboard viewer to compare with your keyboard's shift-Control key combination.
    Also, I've included a short video illustrating the feature working with ViVA.
    Hope this helps Nader!
    Shawn
    P.S. As a side note, I also use a Windows machine with a VDI.
    Figure 1
    Play this video
  • Nader Fathy
    Nader Fathy over 4 years ago in reply to ShawnLogan
    Thank you very much Shawn!
    I am using Exceed TurboX, and I believe there is an issue with it when I use the (Shift-Mouse Wheel) combination. This is why I was looking to change the bindkey. Mouse-Right-Click zoom method still works though as illustrated in your video.
    Kindest Regards,
    Nader Fathy
    Hi Nader,
    Rats! However, I must thank you for letting me know it did not work with Exceed TurboX.
    I have not tried using Exceed TurboX. I have used Exceed (when it was referred to as Hummingbird Exceed). However, it was a while ago when most designers used it simply to emulate an X-window environment on Windows.
    The only other thought that comes to mind is to use a mouse that allows you to program its features (to allow you to re-program the combination that is not working to expand the ViVA x-axis). Just as an example, I use the Evoluent Vertical Mouse (https://evoluent.com/products/vm4r/) on my PC and their software allows you to re-program its various buttons as they show on their site at URL:
    https://evoluent.com/buttons/
    I thought I might at least pass the thought your way as it came to mind Nader. Thank you for letting me know anyway!
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    Hi Nader,
    You might need to contact OpenText for support. I also use a MacBook and whilst it works fine with my VMWare Fusion virtual machine, the shift-mousewheel does not work (as you say) with Exceed TurboX. I took a look at the advanced configuration settings in Exceed TurboX for the connection and can't see anything that would appear to prevent shift-mouse wheel from working (ctrl-mouse wheel is OK).
