  3. cannot delete extraction cellview
  • Views 10298
delgsy
delgsy over 4 years ago
There is one extraction cellview that I want to delete, but somehow I cannot do this.
This is the message from CIW.
How should I format the env var CLS_LOCK_HARD_LINKS?
envSetVal("??????????" "CLS_LOCK_HARD_LINKS" 'boolean t)
    It's a UNIX env var, so you should do:
    setenv CLS_LOCK_HARD_LINKS YES
    or
    export CLS_LOCK_HARD_LINKS=YES
    before starting Virtuoso, or you could probably also do:
    setShellEnvVar("CLS_LOCK_HARD_LINKS" "YES")
    from SKILL.
