  3. How to simulate (equivalent) noise (charge) of CSA?
  • Views 9876
delgsy
delgsy over 4 years ago
I have done this simulation previously when I had only the CSA.
Back then, I used noise analysis, found the output-referred noise voltage, integrated it, and then divided it with the Cf.
Now I have another block after this CSA and would like to include the noise of this circuit and referred the noise to the input.
Conceptually, it is similar like the method I used previously but now I need to divide the output-referred noise voltage with the transfer function of this block.
Is there a simple way to do this?
I prefer to use single testbench to simplify everything.
