  3. ahdlLib quantizer Block
  • Subscribers 136
  • Views 11250
Firdos
Firdos over 4 years ago
I am using quantizer block from ahdlLib block. I am applying a sawtooth wave and then quantized it into 4 levels. Quantized output should be equally quantized in time and value. But somehow I am getting non-uniform quantized output having two end of low duration. Can anyone help me why is it happening and how to solve it?
    If you look at what the model is doing, this is entirely expected. The threshold level will be half way between the four quantised levels (the step is (high-low)/(nlevel-1)) and it will round to the nearest. If you don't want that rounding then set the round parameter to 0, but that would mean that the highest quantisation level is reached only when you are at or above 1V - which may not be what you want.
    You'll need to think about which quantisation levels you want and where you want the thresholds to be.
    Note also that there's nothing to precisely control the quantisation switching points in these models (they don't @cross to control the time step around the threshold crossings) but that probably doesn't matter in most applications.
