  3. CDL netlist format
  • Replies 7
  • Subscribers 136
  • Views 23514
CDL netlist format
1heinz
1heinz over 4 years ago
I have CDL net lists using different ways to connect the substrate pin of a transistor:
Q1 net1 net2 net3 [net4] npn M=1
Q2 net1 net2 net3 npn M=1 $SUB=net4
Q3 net1 net2 net3 net4 npn M=1
Q4 net1 net2 net3 npn area M=1
Which one of the above format is the correct syntax ?
Or do the different tools/versions accept only some of the formats ?
Especially 'Q4' seems to be ambiguous, because "npn" can be an optional substrate node or the model name ?
Heinz
    Hi Heinz,
    The first looks suspicious (the PVS and Pegasus documentation is the best place to look for info on syntax for Cadence tools - the hyperlink is to the Pegasus doc on BJT). I wouldn't expect it to work with the node surrounded by [] - the documentation uses that to indicate that it's optional. Also, the area is expected to be a number, so maybe your last line area is a parameter defined somewhere.
    I can't answer what other non-Cadence tools support. Essentially the 2nd to 4th look OK though (assuming area is a parameter)
  • 1heinz
    1heinz over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    thanks,  I will look into the Pegasus documentation.
    It was my first thought that this is an indication for optional, but at least the assuraCDL command reference contains the following description.
    Transistor (BJT) Syntax
    Qxxx coll base emitter [[nsub]] mname [M=multiplier] [$EA=value] [$L=length] [$W=width] [$SUB=substrate]
    Fields
    [nsub]
    Specifies the SUBSTRATE terminal connection. You must enclose the SUBSTRATE terminal connection name in square brackets.
    Examples
    Q1 c b e [GND] QM M=5 $EA=3.4 $L=2.3 $W=1.2
    Regards Heinz
    Andrew Beckett over 4 years ago in reply to 1heinz
    Good point. It's always the challenge with SPICE-like textual formats that they evolve independently in different tools. I've not checked to see whether the square bracket syntax does indeed work with PVS/Pegasus.
  • 1heinz
    I confirm that '$' is used for optional SPICE-like parts because this is a comment indicator in some dialects.
    But square brackets are not a good idea ;-) but may be necessary to unwind some ambiguity.
    That is why I do not understand how this is handled by different tools.
  • 1heinz
    1heinz over 4 years ago in reply to 1heinz
    only for keeping You updated:
    according to the cadence support (case# 46633599) the brackets mentioned in the assura manual are wrong and the manual will be fixed in the future.
    Only strange thing is that I saw netlists with the brackets in the past.
    I will fix my scripts to accept substrate nodes with and without brackets.
    Regards Heinz
  • hulila bell
    hulila bell over 4 years ago
    Is there any good source on the net explaining the format of a CDL netlist. I need to create a netlist manually because I am using some
    Andrew Beckett over 4 years ago in reply to hulila bell
    I already answered this several months ago in the first reply in the thread. Please look at that.
