  3. how to update "design" when copy testbench
  • Views 2237
sjwprcker
sjwprcker over 4 years ago
I need to copy many test bench from old lib to the new lib. I wish the design of the testbench can be updated by default (to the view in the new lib).
I have set option: update the instance, but seems not work.
Anyone know how to realize such feature?
BR
    This should work provided that you copy both the cellVIew with the reference and the cellView that referenced at the same time, and choose update instances. If you just copy them separately it can't really work out what you intended. This works pretty reliably, so if it doesn't, you should contact customer support so that we can take a look at what might be wrong.
