  3. Netlisting Unsuccessful for PEX Simulation in ADE/ADEXL
  • Views 10235
shbmsra12
shbmsra12 over 4 years ago
Hi All,
I'm encountering an error while generating the netlist in ADE/ADEXL for post-layout simulation of my design. I have used the spectre output (PEX Output) as input of few block of my interest in the config view. When I tried to generate the netlist to make sure good to go for simulation, But the netlist didn't generate and it throws an error. The Error in the CIW is given below.
INFO (SCH-1170): Extracting "mux_v2_w_predriver_final schematic"
INFO (SCH-1426): Schematic check completed with no errors.
INFO (SCH-1181): "tx_2021 mux_v2_w_predriver_final schematic" saved.
generate netlist...
Begin Incremental Netlisting Jun 9 15:18:32 2022
*Error* eval: unbound variable - simPrintInhConnAttributes
End netlisting Jun 9 15:18:32 2022
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
...unsuccessful.
I tried to trace it back if there is some error in the PEX generated spectre output file. But it doesn't shows any error in CIW. The contect of the CIW window is given below.
WARNING (OSSHNL-143): Incremental netlisting is not possible since the global map file '/tmp/shubham/simulation/tb_tx_2021/tb_tx_top_v2_final/adexl/results/data/.tmpADEDir_shubham/tb_tx_2021:tb_tx_top_v2_final:1/tb_tx_2021_tb_tx_top_v2_final_config_spectre/netlist/ihnl/globalmap', could
not be opened in the read mode for IHNL version number comparison. Therefore
re-netlisting the entire design.
INFO (OSSHNL-386): HED 'sourcefile' support is enabled by default. Set variable
'hnlSourceFileDisabled to 't to disable sourcefile support.
INFO (OSSHNL-384): Valid sourcefile '/home/shubham/Shubham_PhD_AMPICLAB/prbs10_8Ch_w_mux_final.pex.netlist' on cell 'tx_2021/prbs10_8Ch_w_mux_final' in config 'tb_tx_2021/tb_tx_top_v2_final/config'. This cell will be treated
as a stop point.
INFO (OSSHNL-384): Valid sourcefile '/home/shubham/Shubham_PhD_AMPICLAB/cml_divider_final.pex.netlist' on cell 'tx_2021/cml_divider_final' in config 'tb_tx_2021/tb_tx_top_v2_final/config'. This cell will be treated
as a stop point.
INFO (OSSHNL-384): Valid sourcefile '/home/shubham/Shubham_PhD_AMPICLAB/8to4_mux.pex.netlist' on cell 'tx_2021/8to4_mux' in config 'tb_tx_2021/tb_tx_top_v2_final/config'. This cell will be treated
as a stop point.
INFO (OSSHNL-384): Valid sourcefile '/home/shubham/Shubham_PhD_AMPICLAB/clock_unit_final_seg_final.pex.netlist' on cell 'tx_2021/clock_unit_final_seg_final' in config 'tb_tx_2021/tb_tx_top_v2_final/config'. This cell will be treated
as a stop point.
INFO (OSSHNL-384): Valid sourcefile '/home/shubham/Shubham_PhD_AMPICLAB/bias_global.pex.netlist' on cell '25G_RING_TX/bias_global' in config 'tb_tx_2021/tb_tx_top_v2_final/config'. This cell will be treated
as a stop point.
End netlisting Jun 9 14:21:16 2022
...unsuccessful.
    I don't know which sub-version of the IC tools you are using (it's always useful to know this, as the forum guidelines request), but one example of where I found this had happened before (from doing some searching, as I've not seen it myself) is where you have a discrepancy between the CDF termOrder and the file you are including (I'm not sure why that would cause a failure like this to be honest. I would however say that using sourcefile in the hierarchy editor isn't the easiest approach, as you need to edit the spectre simulation information in the CDF for the cell to ensure that the termOrder matches that in the included file. Better to create an extracted view or smart view (if using Quantus QRC), or to create a DSPF file from the extraction tool and then include that via the dspf include on Setup->Simulation Files.
  • shbmsra12
    shbmsra12 over 4 years ago in reply to Andrew Beckett
    I'm sorry for not mentioning the version of the tool. I'm Using IC6.17-64b.78 and Spectre version is 15.1.0.257. I vouch about your comment regarding discrepancy between CDF termOrder in schematic netlist and PEX generated netlist. Before utilizing the PEX generated netlist as sourcefile the CDF termOrder needs to arranged as per schematic netlist. Which I had done manually here because earlier Calibre extracted view was taking a lot time to load and simulate. But thanks for telling to use DSPF file. I'll use DSPF from now onwards.
    Regarding the netlist generation,  I was not able to generate the netlist from ADE-L/ADE-XL. But when I fired the simulation through ADE-XL, It ran and I was able to generate the netlist from  the corners tab in the result window in ADE-XL. Eventually the simulation completed successfully as well.  But This is kind of look weird to me on the behavior of the tool.
    Andrew Beckett over 4 years ago in reply to shbmsra12
    I've no idea what has gone on here - I suggest you contact customer support (although ADE XL is end-of-support, so you might want to check with ADE Assembler first).
  • shbmsra12
    Yeah,
    For now, It's working fine. It kind of weird behavior of tool, I don't know. But, I'll surely I'll check with the customer support. Thanks for your Help.
    Best,
    Shubham
