  3. name of nets inside deepprobe
  • Views 13277
Svilen64
Svilen64 over 4 years ago
I am using a DSPF file for the parasitic extraction and I want to use deepprobe at the top level to access voltages on nets deep inside the extracted netlist. I looks there is a disagreement between the syntax of the DSPF and spectre.
For example I have copied the net name as it comes from the DSPF into the deppprobe
IPRB1 (ITOP.Xextr/Xopamp/net1) iprobe
The error says:
Unexpected operator "/", Expected block statement, end of file or end of line
If I remove the deepprobes from the test bench, there are no errors anymore although the DSPF file itself  is full of  "/" everywhere in the net names.
How can I get around this problem?
Svilen
    Svilen,
    The slash is legal in a DSPF file, but not a legal name in spectre syntax and so you need to escape the names to allow them. Enter:
    ITOP.Xextr\/Xopamp\/net1
    in the deepprobe properties.
  • Svilen64
    Svilen64 over 4 years ago in reply to Andrew Beckett
    Thanks. Yes, this works.
