  3. [Verilog-A/AMS] Using a for loop to instantiate module
  • Views 13181
delgsy
delgsy over 4 years ago
I need to generate multiple clocks with different delay.
So, my plan is creating a single delay module and instantiate it using for loop which apply different delay then a single clock will drive all of them.
But I still cannot make it work.
From Ken Kundert's book, it is mentioned that genvar cannot used inside the loop structure.
Is there anything that I can try?
Here is the same code for easy copy-paste.
`include "constants.vams"
`include "disciplines.vams"
`timescale 1ns/1ps
module verAMS_array_delay_v2 (IN, OUT);
    input IN;
    //electrical IN;
    wire IN; //Analog port connections in array of instances is not supported..
    output [0:1] OUT;
    logic [0:1] OUT;
    wire [0:1] OUT;
    genvar i;
    real tdelay_ns;
for (i=0; i<2; i=i+1)
begin
//tdelay_ns = (10*i) + 10;
//verAMS_delay #(.tdelay(tdelay_ns)) (IN, OUT[i]);
verAMS_delay #(.tdelay(30)) (IN, OUT[i]);
end
/* This works.
verAMS_delay #(.tdelay(30)) DUT0 (IN, OUT[0]);
verAMS_delay #(.tdelay(20)) DUT1 (IN, OUT[1]);
endmodule
`timescale 1ns/1ps
module verAMS_delay (IN, OUT );
    input IN;
    electrical IN;
    output OUT;
    logic OUT;
    reg OUT;
    parameter real tdelay  = 20;
initial OUT = 0;
always @(cross(V(IN)-0.6,+1))
    begin
    OUT <= #tdelay 1;
    end
always @(cross(V(IN)-0.6,-1))
    begin
    OUT <= #tdelay 0;
    end
endmodule
    You can put this in the for loop: verAMS_delay #(.tdelay(10*i+10)) (IN, OUT[i]); Andrew
    Andrew Beckett over 4 years ago in reply to delgsy +1
    Unfortunately, this is a known limitation of the netlister's hierarchy traversal, as outlined in this post and this post . These give workarounds (you need to explicitly point to the Verilog-AMS code for…
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    I got this error during simulation.
    It passes extraction though.
    Unfortunately, this is a known limitation of the netlister's hierarchy traversal, as outlined in this post and this post. These give workarounds (you need to explicitly point to the Verilog-AMS code for the lower-level block).
  • delgsy
    It works.
    Thank you very much.
