  3. Skill equivalent of "Open design in tab" in Assembler
  • Views 2933
alexstepanov75
alexstepanov75 over 4 years ago
In Assembler if I RMB one of the tests there is a menu option "Open design in tab"
How I can open the test design in the tab using SKILL?
Thank you.
    There's no dedicated function (as far as I know) but you could use: sevAnnotateResults(axlGetToolSession(axlGetWindowSession() "AC") 'defaults) (in this case "AC" is the test name). Andrew
  • alexstepanov75
    alexstepanov75 over 4 years ago in reply to Andrew Beckett
    Works fine. Thanks!
  • alexstepanov75
    Andrew Beckett Andrew, when I use this function and run sklint to check my SKILL, I am getting following:
    INFO (sevAnnotateResults): ATadexFunctions.il, line 193 (openSchematicForCurrentTest) : This SKILL function is public, but
    should only be used in a .menus file.
    So, is it ok to use this function in skill and not in .menus file?
    Andrew Beckett over 4 years ago in reply to alexstepanov75
    Yes, that's a very old SKILL Lint rule, and it's been applied to a broader range of functions than make sense. Some of the "sev" functions clearly are for the UI, but I don't see this one as being one of them (there's no mention in the documentation of this limited use).
    I'll file a CCR on your behalf to get this tidied up.
  • alexstepanov75
    Thank you.
