  3. Segmentation fault upon VerilogA compilation with an if...
  • Views 11407
Segmentation fault upon VerilogA compilation with an if condition
AAbdelRahman
AAbdelRahman over 4 years ago
I am currently using ICADVM20.1-64b.500.24 and SPECTRE21.1.0.334.isr6 64bit. I already passed checksysconf for those and other cadence tools I currently have. My OS is CentOS 7. The server has 1TB of RAM, 64 cores (128 threads), and plenty of storage space. I am already using "unlimit stacksize"
When I compile the simple attached verilogA file, it gives away a segmentation fault. This is during compilation and not even simulations.
Fullscreen new_res_estim.txt Download
// VerilogA for behavioral_blocks, new_res_estim, veriloga
`include "constants.vams"
`include "disciplines.vams"
module new_res_estim(in, sk, out);
input in, sk;
output out;
electrical in, sk, out;
parameter integer freeze = 0 from [0:1];
if (freeze == 0)
analog @(initial_step) $display("hello_world");
endmodule
When I change the condition to "freeze ==1" which is the opposite of what I want, it compiles successfully. When I change it "freeze!=1" it fails again.
Going back to an older version seems to fix the problem. For example, using ICADVM20.1 ISR21 and SPECTRE21.1 ISR1 compilation is successful.
I have been facing other "random segment faults" during simulations and I don't know if those things are somehow related.
Best regards.
Ahmed
    Ahmed,
    I don't see this problem - it compiles successfully with me. I suggest you contact customer support.
  • delgsy
    delgsy over 4 years ago
    curious with hello_world in verilogA so I tried to compile it.
    well, just want to say, It compiles ok on my pc.
  • AAbdelRahman
    AAbdelRahman over 4 years ago in reply to Andrew Beckett
    Thanks for your reply.
    I will do that.
    Best regards,
    Ahmed
  • AAbdelRahman
    AAbdelRahman over 4 years ago in reply to delgsy
    Hi Delgsy,
    Thanks for letting me know.
    Best regards,
    Ahmed
