  3. Grouping instances in layout
  • Subscribers 136
  • Views 11486
Senan
Senan over 4 years ago
I have a basic issue, in the layout design I need to creat a group of some implemented devices, example I want to make the differential pair matched transistors as a one group after I have layouted them, so I can move them safely as a one device.
I have tried to use Edit > group, I got three points pointers then I make square over the devices but nothing is grouped.
Thank you for your help
Regards
    That's only for when you want to add to an existing group. Instead select the objects you want and do Create->Group, or if nothing is selected you can do Create->Group, select the objects (as prompted) and then either Apply the popup form or hit Enter.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew very much for your help,
    That was perfect.
    Have a nice time
    Regards
