  3. The way to define variable correlated to ac simulation in...
  • Views 9841
The way to define variable correlated to ac simulation in .scs model
sjwprcker
sjwprcker over 4 years ago
Greetings,
I would like to run AC sim in one test once in case of two sub-conditions
1) ac source1 active with acm1 = 1, ac source2 off with acm2=0
2) ac source1 off with acm1 = 0, ac source2 active with acm2=1
so i define such an ac_analysis.scs and load it the corner setup as
section ac_analysis
ac1 ac start=0.1 stop=10M dec=50 acm1=1 acm2=0
ac2 ac start=0.1 stop=10M dec=50 acm1=0 acm2=1
endsection ac_analysis
However, maestro can not recognize the difference of acm1 and acm2. So how i can improve the .scs model?
Thanks.
    It's not really "maestro" not being able to recognise this. You have invalid ac analysis statements in spectre - you can't just change netlist parameters on an analysis line - the parameters on the analysis line are analysis parameters.
    You can do this with alters:
    section ac_analysis
    alt1 alter param=acm1 value=1
    alt2 alter param=acm2 value=0
    alt3 alter param=acm1 value=0
    alt4 alter param=acm2 value=1
