  3. Verilog netlist wont explicit bit connected to bus pin
  • Views 9966
YB36
YB36 over 4 years ago
Im using verilog netlister (lunch--> plugins-->simuilation--> systemVerilog) to netlist my schematic.
Now I have an instance with 32 bit pin input (input rstb<31:0>).
In the schematic I connected a net to between this pin to one pin output of other instance.
Now the schematic (and any analog netlister ) is smart enough to understand that this 1 pin should drive the all 32 bit.
But when creating verilog netlis it will connect only bit (something like  .rts_b(father_1_bit_net) ... ).
  Actually I know this thing will depend on the various env variable and I do have .simrc file looks something like this:
simVerilogNetlistExplicit = 't
hnlVerilogNetlistBehavioralExplicit = 't
hnlVerilogNetlistNonStopCellExplicit = 't
simVerilogTestFixtureFlag = 'nil
simVerilogTestFixtureTemplate = 'nil
vlogifInternalTestFixtureFlag = 'nil
hnlVerilogTermSyncUp = "mergeAll"
simVerilogDropPortRange = 't
Version: ICADVM20.1-64b.500.24
