  3. How to create auto pin under the cursor select
  • Subscribers 136
  • Views 12142
TonyTang
TonyTang over 4 years ago
While I use create pin by auto mode, the new generated pin always put on start or end of line. I want to let the pln location follow the cursor select.
How can I achieve it? Thank you.
  • TonyTang
    If turn on "Pin size" option, the pin placement location can under cursor. But I still hope its pin shape size fit as line width, and auto placed inside line shape.  looks turn on this option is not a good way to my request.
    Andrew Beckett over 4 years ago in reply to TonyTang
    Turn off the Snap to wire end on the Create Pin form (and leave Pin Size unchecked).
  • TonyTang
    TonyTang over 4 years ago in reply to Andrew Beckett
    Thanks for your answer.
    I am sorry that I can't find "snap to wire end" option in create pin form?There is a Snap mode menu, I tried it not related to wire end setting.
    Is it an env variable?
    • Vote Up -1 Vote Down
    My guess is that you must be using a rather old version (this is why the guidelines ask you to specify the version number, as it helps to understand this kind of issue). The "snap to wire end" option was added in IC6.1.7-64b.500.16 (ISR16) and the same sub-version of ICADV12.3, back in 2017. I think you're probably using an older version - what does Help->About show in any of the windows?
  • TonyTang
    Thank you so much, I get this option while I swtich to a new version.
    It can work well to meet my request if I turn off "snap to wire end" .
  • Adam54
    Adam54 over 4 years ago
    Make sure the Snap to Wire end is turned off when creating pins (along with leaving the Pin Size box unchecked).I hope this will fix your issue.
