  3. How to change Default Decend View type
  • Views 15183
SpiceMonkey
SpiceMonkey over 4 years ago
I dont know why, the default decend view "schematic" should be prior to others, but now it changes to "schematic_behav", (Figure 1)
And another strange problem is when I Check Hierachy, the "schematic_behav" is also prior to "schematic" (Figure 2), what could I do to set search "schematic" first, thank you!
    Andrew Beckett over 4 years ago in reply to SpiceMonkey +1
    Look at Edit->Properties->CellView on the specific cellView that has the problem. I expect that there is a property called viewNameList stored on the cellView as that is used to set the default value of…
    Are you using a config view and viewing the configured schematic? If so, the default view for descend is whatever the view to use is for that instance - which is governed by the rules set in the hierarchy editor.
    Alternatively, it's what is set in the Schematic Options->Editor in the View Name List field.
    ShawnLogan over 4 years ago in reply to Andrew Beckett
    Dear SpiceMonkey,
    Just to add to Andrew's accurate response if it is not clear to you...
    You can change the default order as Andrew notes using the Options->Editor pulldown menu item in Virtuoso as shown in Figure 1. As shown in Figure 2, the default list view order can be changed using the red circled dialog box from the "Commands" tab.
    I hope this helps to make Andrew's suggestion even more clear SpiceMonkey...
    Shawn
    Figure 1
    Figure 2
  • SpiceMonkey
    SpiceMonkey over 4 years ago in reply to Andrew Beckett
    Thank you Andrew! I didn't use configured schematic... I recreated a schematic and solved the probelm... Maybe some problems related to "Cliosoft SOS"
    Change of "Schematic Options->Editor" works temporarily  when I re-open the problem is still there.. The configuration of "View Name List" seems to be saved in this specific cellview (other top schematics which contain "schmatic_behav" don't have this problem). Anyway, many thanks!
  • SpiceMonkey
    SpiceMonkey over 4 years ago in reply to ShawnLogan
    Thank you Shawn. It works temporarily when I re-open the problem is still there.. I recreated a schematic and solved the probelm.
    Look at Edit->Properties->CellView on the specific cellView that has the problem. I expect that there is a property called viewNameList stored on the cellView as that is used to set the default value of the View Name List for that specific cellView. If that's not there, it defaults back to the schematic viewNameList cdsenv variable.
    If there is a viewNameList property in the cellView properties, you can delete the property, and that will fix the issue for that cellView.
  • SpiceMonkey
    There is indeed such a property! thank you!
