  3. Empty R reporting in Parasitic Backannotation
  • Views 9952
delgsy
delgsy over 4 years ago
I was following Parasitic Aware Design Flow RAK and everything works well if I used the simulation results provided from the RAK.
However I cannot have R reporting works if I simulate the circuit myself.
Now the same thing happens on my circuits.
Choosing "All Nets" renders the results NA, both in the report and schematic.
Running DC simulation does not solve the problem.
I am still trying to understand this flow and features, so most probably I missed something.
Is there anything that I can check?
If I choose Terminal to Terminal, it shows some results and the result seems make sense.
Is there a way to display this Terminal to Terminal in the schematic, instead of Net resistance ?
    The effective resistance relies on the DC analysis data, so it sounds as if you've not got that loaded. There are a number of ways through the flow, so probably best if you follow up with customer support.
