  3. cdsterm info sometimes does not show?
  • Replies 8
  • Views 14530
kenc184
kenc184 over 4 years ago
I often have situations where some, but not all of my cdsterm node voltages don't show.
For example, the following cell originally had lower case r and s inputs, the voltages showed when I enabled annotations> transient voltages.
But after changing the lower cases on the symbols to upper case, they no longer show.  Yes, I changed the cdsterm to uppercase also. I did a "refresh" to no avail.
Any ideas?
    Did you renetlist and simulate after making the change?
  • kenc184
    kenc184 over 4 years ago in reply to Andrew Beckett
    Yes, I did..
    Andrew Beckett over 4 years ago in reply to kenc184
    I can't imagine what would cause this - I've not seen that behaviour. Could you please report this to customer support so that it can be investigated?
  • kenc184
    Next time it happens.  However, it might not, as I discovered from these forums that an entry into the .cdsenv file will create the cdsterm
    automatically.  Wish I had known that ten years ago!
  • kenc184
    That was interesting. I had the cdsterms added automatically, and they didn't show up on the top level schematic.  I THINK I know why I have had this issue - certainly it was true in this case - I had none of the relevant nodes saved, I had "save selected" , and none of this block's I/O were.
  • kenc184
    LOL.......it continues.
    With the "analog template" , I get the cdsterms automatically which is nice, but I don't get the part name in the symbol any more.
    IF I go create>label>    then choose NLPLabel, logical label, it does indeed add [@partName] which used to happen automatically.
    However, the part name is not visible when the symbol is instantiated in a schematic!
    The analog template uses cdsName() labels instead of NLP [@partName]. The default/digital template does two things:
    1. Add a partName property to the symbol
    2. Add a [@partName] NLP label to the symbol
    Now, you could adapt the analog/artist template using a similar approach to that described in this post: automatically populate [@cellName] instead of [@partName] when generating a symbol from schematic. You'd have to use a symbolProps section similar to that in the default.tsg file and a defLabel section to add the label.
    Or you could just manually add a [@cellName] NLP label yourself (rather than [@partName]). That will pick up the attribute of the cell rather than relying on an additional property which has to be set to be the same as the cell name.
  • kenc184
    Manually modifying  [@partName] to [@cellName] worked perfectly, thanks.
    It's still much less work to have to do this than to have to add the  cdsterms manually
    Any reason why this could not be made the default for the analog/artist template?  I don't know why anyone would want a symbol without the cell or part name in it?
