  3. is there any way of extracting terminal charge
  • Views 9736
Yea Chul
Yea Chul over 4 years ago
Spectre (R) Circuit Simulator
version: 19.1
Dear all,
i wander if there is a way of extracting terminal charge including extrinsic properties like gatemod effect,,
thanks in advance
    What's "gatemod effect"? To get the charge, can't you just integrate the current? It's very unclear what you really want to do here.
  • Yea Chul
    Yea Chul over 4 years ago in reply to Andrew Beckett
    i meant rgatemod which is one of the BSIM4 parameters
    and i agree with that we can extract the charge from integrating current
    but what i really want to know is to extract charge directly without any calculating
    say, when we use captab, then we can get node to node capacitance
    like this, if i would use some syntax, then i could get terminal chage
