  3. Importing and simulating .cir spice file in Cadence
  • Views 16751
delgsy
delgsy over 4 years ago
I am following the steps explained here.
But it seems that cadence cannot understand the resistor netlist expression.
I used the .cir file from here.
in .cir file:
Rxxx   terminal1   terminal2    r_model_name    r_value
in spectre:
Rxxx (terminal1 terminal2) resistor r=r_value
from log file:
I tried other way that is importing spice file from CIW.
It gives more problem, i.e., more errors, than the way I did above.
Is there anything that I can try?
    Andrew Beckett over 4 years ago in reply to ShawnLogan +1
    Shawn, delgsy This has been the behaviour of Spectre for a good 20 years if my memory is correct (the .scs suffix only being used for spectre), so it's not due to the version number used. The issue…
    ShawnLogan over 4 years ago
    Dear delgsy,
    As noted in the link you included in your Forum post, did you add the following lines:
    simulator lang=spice
    spice macro subckt netlist
    as the first few lines of the ".cir" file you referenced?
    Shawn
    Shawn,
    That shouldn't be necessary. Anything without a .scs suffix will be treated as SPICE anyway. I'm just doing some checks on the file to see how it behaves.
    ShawnLogan over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    I do recall you mentioning that to me sometime ago - but was not sure of the version of software delgsy was using and thought it worth at least trying. Thank you for your correction.
    Shawn
    Shawn, delgsy
    The issue is that you should treat the file as a PSPICE model (there's a comment in the model that also suggests that it's been tested with PSPICE). I tried running a quick command-line simulation using pspice_include in spectre and all ways OK.
    In the article pointed at, then for the various methods (each bullet number is the method in that article)
    1. Use -lang pspice with cdsTextTo5x
    2. Specify the type of the view as "Pspice" if creating a view this way
    3. In the last step, instead of including the file as a model library, use Setup->Simulation Files and include it in the pspice files
    4. Don't use this approach
    5. Or this approach - there's no PSPICE File->Import support
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    Hi Andrew, Shawn,
    I use method 3, put the .cir file in the Setup -> Simulation Files -> Psipice files, and without doing any modification on the original .cir file.
    It works.
    Previously, I used method 3 as well but put the .cir file as a model library.
    Thank you!
