  3. measuring setup and hold in adel/mastero
  • Views 5799
hdeshmukhnvidia
hdeshmukhnvidia over 4 years ago
I am trying to measure setup and hold in adel/mastero, I was wondering is there is any in build function to do this, I found out that specter has a function "dyn_setuphold" but it doesn't have any example on how to use it , the function can be found in "Spectre Circuit Simulator Reference" can some one comment with an example on how to measure setup and hold using any function or measure statement
    ShawnLogan over 4 years ago
    Dear hdeshmukhnvidia,
    The only "built-in" means I am aware of uses spectre MDL if you are familiar with it. There is an application note at the Cadence Onl-line support portal at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    However, I have performed setup/hold time analyses many times using Assembler or Explorer. Most recently, I described the basic methodology for a Forum poster who was looking to determine the noise margin for a comparator - which has a very similar set of simulations. The last entry to the Forum post at URL:
    community.cadence.com/.../can-i-pass-value-between-runs-in-transient-noise-simulation
    describes this. Basically, vary the delay of one signal relative to the other signal by a range of small increments and compute the propagation delay for each of the simulations. Normalize the delay to the value where no metastable or setup/hold violations occur and plot the propagation delay as a function of delay time. The most common definition for setup/hold times sets the respective value to the value where the propagation delay exceeds its normalized value by 1.01 (or 1%). An example is shown in Figure 1.
    Shawn
    Figure 1
  • FormerMember
    FormerMember over 4 years ago in reply to ShawnLogan
