  3. plot problem waveVswave[IM3 vs Pout]
  • Views 2269
atwinter
atwinter over 4 years ago
Hello there!,
I have a question related to waveform(waveVswave)....After i do the hb simulation(2tone), I want to plot IM3[dBc] VS Pout[dBm]
Does work well on IM3[dBc] VS Pin(dBm),
but IM3[dBc] VS Pout/(dBm) not working, I haven't been able to get this formula to work in any way.
IM3[dBc] equation : (value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "3rd Order") - value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "1st Order")) -> plot ok!
Powerout equation : dbm(pvr('hb "/I2/POUT" "/gnd!" 50.0 '((1 0)))) -> plot ok!
and I try to this
db10(waveVsWave(?y (value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "3rd Order") - value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "1st Order")) ?x dBm(pvr('hb "/I2/RFOUT" "/gnd!" 50.0 '(1))) ?xName "Pout(H1)" ?xUnits "dBm" ?yName IM3")) -> plot fail
(error massage :Hence the two waves can't be plotted against each other.)
it doesn't work.
How can I this problem?
    ShawnLogan over 4 years ago
    Dear atwinter,
    atwinter said:
    and I try to this
    it doesn't work.
    i believe I understand your problem. I do not know, however,  the characteristics of the x and y-axis waveform arguments to the waveVsWave() function. From your posting, it appears each argument can be plotted in ViVA successfully. However, I do not know if the waveVsWave y argument of:
    "(value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "3rd Order") - value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "1st Order"))"
    is always non-zero and positive. If it is negative or zero, then the db10 function you have applied to the waveVsWave() output will not produce a valid value.
    1. Have you inspected the values of the ViVA plotted signal "(value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "3rd Order") - value(ipnVRICurves((v("/I2/POUT" ?result "hb_mt_fi") - 0.0) '(2 -1) '(1 0) ?rport resultParam("I2.PORT2:r" ?result "hb_mt_fi") ?epoint -40) "trace" "1st Order"))" by exporting them to a table?
    1a. Are all values greater than 0?
    2. Are you able to plot the following:
    Just a thought...
    Shawn
