  3. How to influence Assembler Monte-Carlo execution regarding...
  • Views 9432
How to influence Assembler Monte-Carlo execution regarding Tests in the presence of calcVal?
StephanWeber
StephanWeber over 4 years ago
I see that for dependent tests using calcVal, these tests are often only executed if all points for the 1st test are done. So in case of problems in the last dependent tests, I see them very late. It would be nice to be able to force running 1st through all tests, then taking the next MC point.
This would be also nicer in case of stopping the run erlier, because then I would have almost equal MC points for each tests, not just e.g. all points from test #1, and only a few from the dependent tests.
Bye Stephan
