  3. final original layout for Parasitic Aware Design Flow R...
  • Views 9732
final original layout for Parasitic Aware Design Flow RAK
delgsy
delgsy over 4 years ago
I cannot find the final original layout in the folder.
My plan is I want to do extraction by myself.
The extracted results and other layout are there except the one that I am looking for.
or is there any thing that I miss?
    No, it's missing. I quickly checked with the author of the RAK, and he's going to check - but the best thing is to contact customer support so that he can follow up directly. Note that the RAK doesn…
    Note that the RAK doesn't include the LVS rules or extraction decks, so it's not really set up for you to re-run this, although I guess you could use the data from the gpdk045 PDK instead.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, for the confirmation and suggestion.
