  3. Saving State in Maestro View as a Spectre State to Open...
  • Subscribers 136
  • Views 6151
Saving State in Maestro View as a Spectre State to Open in ADE L/XL/Midas
jackrc11
jackrc11 over 4 years ago
I have seen it is possible to migrate an existing state from ADE L/XL to Maestro (to Explorer/Assembler, respectively). If a file was originally created as a maestro view, is there a reverse process to save a test (that opens in Explorer or Assembler) as a spectre state/spectre view to be opened in ADE L/XL? I am trying to compare the results from running Monte Carlo simulations in Midas (which seems to require a spectre view) and Maestro, as the settings are somewhat different.
    No, there is no backwards route - mainly because Maestro is a superset and so it would have to drop information.
    Not sure what "Midas" is (the only Midas I've heard of is this simulator from Stanford)
  • firebolt
    firebolt over 4 years ago
    Only option is to export Maestro variables, outputs, corners seperately and then import in Adexl.
