  3. Can I use dynamic variable names in Spectre?
  • Views 10324
SteveVrk
SteveVrk over 4 years ago
I have a sub circuit which is created using a script. When I instantiate it via Virtuoso, I use a CDF parameter "id" which is a numeric value.
Inside the netlist for this sub circuit, I would like to use this CDF parameter to reference a variable "resistance_$id_x". Example:
simulator lang=spectre
subckt test In Out
parameters id=1
   RTest (In Out) resistor r=strcat("resistance_", id, "_x")
ends test
Then, in a different file I would have:
resistance_1_x 1000
resistance_2_x 2000
Is this possible?
    No, it's not possible. You could of course do it if the block was a schematic PCell rather than a generated netlist. Regards, Andrew
  • SteveVrk
    SteveVrk over 4 years ago in reply to Andrew Beckett
    Thanks.
