  3. adel can not sub jobs when I install lsf patch lsf10.1_lnx310...
  • Views 10223
adel can not sub jobs when I install lsf patch lsf10.1_lnx310-lib217-x86_64-601088 or 600488
edafans
edafans over 4 years ago
adel & adeGXL can sub jobs when I install lsf patch lsf10.1_lnx310-lib217-x86_64-509238 ,but adel & adeGXL can not sub jobs when install lsf patch lsf10.1_lnx310-lib217-x86_64-601088 or 600488
when host mode with distributed that error info flowing:
Loading adpServer.cxt
Loading msgHandler.cxt
ERROR (53) : A connection could not be established with the LSF daemon.
Please verify the LSF setup.
1. Check if "bsub" command can be run from the terminal.
2. Check if the process "cdsfrb_lsf" is running on the system.
3. Please consult your LSF administrator for help in resolving these setup issues.
ERROR (39) : There was an error connecting to the Analog Design Environment Distributed job
server service. This host may not be set up correctly for using
Distributed Processing.
WARNING (ADE-3015): Could not initialize Cadence Analog Distributed Processing option.
But , I can bsub any job in terminal .
Other:I can run bsub and cdsfrb_lsf in terminal.
    You didn't mention which IC subversion you're using. There have been some recent-sh updates to support newer LSF versions: LBS option not visible in ADE Job Policy Setup form when using LSF 10.1.12
    If you're using a newer IC version than IC6.1.8-64.500.23 (or equivalent ICADVM20.1 version), then please contact customer support.
