  3. Getting pulse width values with cross function (non-periodic...
  • Views 13292
Getting pulse width values with cross function (non-periodic signal) using Calculator
Johanny Saenz
Johanny Saenz over 4 years ago
Hi all.
I want to get a vector of pulse width values for a non-periodic square signal using Calculator.
I'm using cross() function to perform measurements in the following way:
cross(VT("/p10keV1") 1.65 1 "falling"  t "time"  )-cross(VT("/p10keV1") 1.65 1 "rising"  t "time"  )
However, this expression just return the first substraction, not an array substraction (Be aware that I'm using multiple values on cross()).
What should I change to get all the arrays?
Thanks.
Jorge
    Jorge, Using "cycle" makes sense instead - that way the x-axis points for each cycle will align (otherwise the two transistions will be at different times): cross(v("CK" ?result "tran-tran") 0.5 1…
    Jorge,
    cross(v("CK" ?result "tran-tran") 0.5 1 "falling"  t "cycle"  nil )-cross(v("CK" ?result "tran-tran") 0.5 1 "rising"  t "cycle"  nil )
  • Johanny Saenz
    Johanny Saenz over 4 years ago in reply to Andrew Beckett
    Thanks. It works as I wanted it.
