  3. Cadence Schematic - customizing DC Operating Points annotation...
  • Views 6002
Cadence Schematic - customizing DC Operating Points annotation permanently
firebolt
firebolt over 4 years ago
I can customize operating points displayed on schematic temporarily using Annotation Setup. There is a option to save the setup. On relaunching Cadence or for different schematic, I have to setup again. Is there a way to modify the list permanenlty using cdsinit or any other method?
    This blog should help: https://community.cadence.com/cadence_blogs_8/b/cic/posts/virtuosity-sharing-and-automatically-loading-ade-annotation-settings Andrew
    Andrew Beckett over 4 years ago in reply to firebolt +1
    Assuming that this label on the symbol is on the device/annotate layer purpose pair (which is the usual convention for a [@cellName] NLP label), you can turn them off using: techGetLP(techGetTechFile…
  • firebolt
    firebolt over 4 years ago in reply to Andrew Beckett
    Thanks Andrew. How to remove this yellow text definition? It's not in annotation setup.
    techGetLP(techGetTechFile(geGetEditCellView()) '("device" "annotate"))~>visible=nil hiRedraw()
    Other than changing the technology file to turn off visibility of device/annotate by default, there's not really a way of doing it by default. I guess you could put:
    techGetLP(techGetTechFile(ddGetObj("gpdk045")) '("device" "annotate"))~>visible=nil
    or similar in your .cdsinit - replacing gpdk045 with your technology library name. You can then get them back by using View->Show Instance Labels in the schematic editor.
  • firebolt
    Thanks Andrew. These cdsinit definitions are working.
    To set default annotation -> envSetVal("auCore.misc" "annotationSetupFileList" 'string “<pathToMyAnnotationSetup>.as")
    To set bindkey for DC op annotaion -> hiSetBindKey("Schematics" "2" "annLoadAnnotationData(hiGetCurrentWindow() \"<pathTo/.cadence/DCannotationSetup.as>\")")
