  3. difference between "temp" & "tnom"
  • Views 5026
sjwprcker
sjwprcker over 4 years ago
What is the difference between "temp" and "tnom" in the dynamic parameter option?
BR
    From the "spectre -h options" help:
    Temperature parameters
    6 temp=27 C* Temperature.
    7 tnom=27 C* Temperature measurement of the default component parameter.
    What this means is that tnom is the nominal temperature at which the models were characterised. It would be unusual to change that globally (there is a model parameter for this too usually). The temp is the actual simulation temperature though, which is more likely to be something you'd want to change.
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for your feedback! quite clear for me.
