  3. maestro runs complete counter disappears
  • Replies 7
  • Views 13421
Pirate King
Pirate King over 4 years ago
In a maestro once a run is started a counter appears on the bottom frame of the window showing the number of runs complete x/y and a percentage counter. Sometimes this does not appear after a run start and I cant find a menu option or right click option to bring it back. If this does not appear then what other method is there to see runs progress?
  • FormerMember
    FormerMember over 4 years ago
    Dear
    ShawnLogan over 4 years ago in reply to FormerMember
    Dear Pirate King,
    I have never experienced this behavior and hence cannot comment on your request to "restore" this behavior. As Andrew often suggests, ti would be very helpful to know the version(s) of the tools you are using.
    Nevertheless, I can offer a UNIX script I use to monitor Maestro jobs with a bit more detail. I use this quite frequently to monitor in real time how many simulations in a run are complete and to examine how far they have progressed. It can also be used to find any jobs that do not complete successfully. The script is run from the Maestro directory level where the Interactive.X directories are located. To monitor the status of job Interactive.Y, one types at the UNIX prompt:
    $ progressxl Y
    The script descends into all corner simulations in Interactive.Y and prints the last line of each jobs spectre.out file. Using a UNIX grep it can easily be filtered to show you how many jobs are complete, how many are running, or how many have failed with an error.
    For example, here is the contents of a set Maestro corner runs:
    $ ls
    ExplorerRun.0 Interactive.0 Interactive.2 Interactive.4 Interactive.6
    ExplorerRun.1 Interactive.1 Interactive.3 Interactive.5 Interactive.7
    Interactive.0 has only one corner and produces the following with the "progressxl" script
    $ progressxl 0
    Scanning directories
    Checking 1...
    spectre completes with 0 errors, 4 warnings, and 6 notices.
    Finished scanning directories...
    To count the number of jobs that complete with 0 errors, use the UNIX command:
    $ progressxl 0 | grep -c "0 errors"
    1
    If you are interested, the script is attached. Remove the ".txt" extension (only added to allow me to upload file to this post). Make the file executable and place it in your ~/bin directory to allow you to access it from any directory (assuming ~/bin is in your PATH variable).
    Shawn
    Fullscreen progressxl.txt Download
    #!/bin/ksh
    if [ $# -ne 1 ]; then
        echo "Usage: progress Interactive.<number>"
        exit 127
    fi
    # First head down through all of the directories recursively
      echo "Scanning directories"
      #SAU_DIR_LIST=`t`
      SAU_DIR_LIST=`ls Interactive.$1 | grep "[0-9]"`
      for SUB_DIR in ${SAU_DIR_LIST}
      do
        echo "Checking ${SUB_DIR}..."
        if [ ! -d "./Interactive.$1/${SUB_DIR}" ]
        then
          echo "${SUB_DIR} is not a directory - skipping."
        else
          # grep Current ${SUB_DIR}/psf/spectre.out
          tail -1 ./Interactive.$1/${SUB_DIR}/sd*/psf/spectre.out 2>/dev/null
        fi
      done
      echo "Finished scanning directories..."
  • Pirate King
    Pirate King over 4 years ago in reply to ShawnLogan
    Thank you Shawn , i shall give this a go. The version i am using is IC6.1.8-64b.500.19
    Incidentally it has just disappeared again now and I believe after i opened the design in a tab.
  • Pirate King
    Pirate King over 4 years ago in reply to Pirate King
    yes just switching tabs then coming back to maestro the percentage complete meter does not come back. So the advice is to keep the maestro tab on view all the time and if you want to view the schematic open it as a separate view and not as a tab on the maestro
    ShawnLogan over 4 years ago in reply to Pirate King
    Dear Pirate King,
    Interesting and thank you Pirate King!
    I just started a set of 17 corner simulations in Assembler and, prior to starting the run, opened the schematic in a separate tab by right clicking on the test ("Open design in tab"). I switched back and forth a few times between the schematic tab and Maestro tab and did not observe the status bar changing as the number of simulations running remained. I am using a different version than you, but don't ever recall that behavior.
    I did not see this issue identified as one on the Cadence On-line Support site, but will not suggest my search was perfect!
    Without a few more details on your specific simulation setup (method of job submission, job policy, etc...), I am unable to think of any further suggestions that might be fruitful and don't want to waste your time with possible ideas that are not at all relevant. Sorry!
    Shawn
  • Pirate King
    Thanks Shawn, i should have mentioned that the meastro is an Explorer maestro and opened as Explorer as we dont use Assembler
    Andrew Beckett over 4 years ago in reply to Pirate King
    It's a known issue with multiple duplicate requests to fix. CCR 2007511 is the master change request for this, so feel free to contact support and request a duplicate. The problem occurs in Explorer if you switch tabs during simulation (yes, it really should be fixed, but the fix has not been prioritised yet).
