  3. specify editor for ADE Explorer documents
  • Subscribers 136
  • Views 10592
drdanmc
drdanmc over 4 years ago
Is there a way to specify what editor will be used for opening a document in ADE Explorer?  I have an Ocean file (.ocn suffix) and when I open it, it is coming up in gedit and I'd prefer xemacs.  The "editor" SKILL variable doesn't seem to take in this case.
-Dan
  • henker
    henker over 4 years ago
    It uses the freedesktop style file association database of your underlying desktop system.
    How to add/modify the file associations via GUI depends on your window/file manager;
    e.g. in KDE its in the Menu -> System Settings -> File Associations.
    Other option is to manually edit the local user database in ~/.local/share/applications (or edit the global database for all users).
    An overview can be found e.g. on www.freedesktop.org/.../
  • drdanmc
    drdanmc over 4 years ago in reply to henker
    Thanks!  It's working now.  In case someone else is looking or I find my own question in 5 years:
    mkdir -p ~/.local/share/mime/packages/
    cat > ~/.local/share/mime/packages/application-x-ocean.xml <<EOF
    <?xml version="1.0" encoding="UTF-8"?>
      <mime-info xmlns="">www.freedesktop.org/.../shared-mime-info">
      <mime-type type="application/x-ocean">
        <comment>Cadence Ocean File</comment>
        <glob pattern="*.ocn"/>
      </mime-type>
    </mime-info>
    EOF
    cp ~/.local/share/mime/packages/application-x-ocean.xml ~/.local/share/mime/packages/application-x-skill.xml
    cp ~/.local/share/mime/packages/application-x-ocean.xml ~/.local/share/mime/packages/'application-x-skill++.xml'
    # edit the SKILL and SKILL++ files to set extensions to .il and .ils respectively and change from
    # Ocean to SKILL and SKILL++
    vi ~/.local/share/mime/packages/application-x-skill*
    mkdir -p ~/.local/share/applications/
    cat > ~/.local/share/applications/ocean-editor.desktop << EOF
    [Desktop Entry]
    Type=Application
    MimeType=application/x-ocean
    Name=Cadence Ocean
    Exec=xemacs
    EOF
    cp ~/.local/share/applications/ocean-editor.desktop ~/.local/share/applications/skill-editor.desktop
    cp ~/.local/share/applications/ocean-editor.desktop ~/.local/share/applications/skill++-editor.desktop
    vi ~/.local/share/applications/skill*.desktop
    update-mime-database ~/.local/share/mime
    update-desktop-database ~/.local/share/applications
    # check
    gio mime application/x-ocean
    gio mime application/x-skill
    gio mime application/x-skillx
    gio mime application/x-skill++
    touch /tmp/myfile.ocn
    gio info /tmp/myfile.ocn | grep "standard::content-type"
    Thanks again for pointing me in the right direction.
    -Dan
  • drdanmc
    Thanks.  That worked.  I added a longer reply detailing exactly what I did for it to work but it triggered some sort of content filter.
    Andrew Beckett over 4 years ago in reply to drdanmc
    Thanks Dan. This went into moderation because the repeated text causes the forum software to consider it as potentially spam. I was on vacation and not reading emails, so only just saw this...
