  3. Virtuoso Constraints SKILL code: correct my cstFindFirstConstraint...
  • Views 10674
Virtuoso Constraints SKILL code: correct my cstFindFirstConstraint syntax
dfink
dfink over 4 years ago
I'm trying to get the ConstraintID of a particular constraint in the tech file foundry CG:
orderedSpacings(
( minOppExtension "METAL5" "VIA45" (0.020 0.11) 'ref "Mn.EN.1 Mn.EN.2" )
my skill code:
techdb = techGetTechFile( ddGetObj("tsmc13rf"))
FoundryID = cstFindConstraintGroupIn(techdb "foundry")
ConstID = cstFindFirstConstraint(FoundryID "minOppExtension" list("METAL5") list(0.02 0.11)
println(ConstID)
Running this code in the CIW gives:
*WARNING* (CST-300016): Constraint def 'minOppExtension' is not a layer constraint registry.
nil
t
The cstFindFirstConstraint is failing with ConstID having a nil value.
Why is this warning happening?  Please help me understand how to properly format the t_constraintDefName in the cstFindFirstConstraint.
  • dfink
    correction:  the ConstID variable set command does have the 2nd closing parenthesis in my code, just missed it when copying it to this post:
    ConstID = cstFindFirstConstraint(FoundryID ConstDef list("METAL5") list(0.02 0.11))
  • dfink
    I found a solution.
    I'm guessing that because minOppExtension is 2 layer check, the cstFindFirstConstraint expects tx_layer... to be a list of the 2 layers from the minOppExtension ordered spacing.  It fails if only 1 layer is provided to cstFindFirstConstraint.
    cstFindFirstConstraint works after I provided the list of both layers:
    ConstID = cstFindFirstConstraint(FoundryID "minOppExtension" list("METAL5" "VIA45") )
    specifying the extension parameter numbers also works:
    ConstID = cstFindFirstConstraint(FoundryID "minOppExtension" list("METAL5" "VIA45") list(list(0.020 0.11)))
  • dfink
    The content of this warning leaves much to be desired:
    It is not descriptive of the issue at all and even a bit misleading..
