  3. trapezoidal ringing with spectreX
  • Subscribers 136
  • Views 20271
sjwprcker
sjwprcker over 4 years ago
I try spectreX to speed up the simulation.
With "preset" = MX/AX, the tran waveform displays trapezoidal ringing.
With "preset" = CX, the ringing disappear, but paying more time and license.
Is there any way to avoid trapezoidal ringing with MX/AX in spectreX? (I suppose they are already analog precise enough)
The tran algorithm is set gear2only.
More info
When i use APS and errpreset = moderate, there is no ringing.
BR
    ShawnLogan over 4 years ago
    Dear sjwprcker,
    Did you happen to see the note entitled "Getting the Most Out of Spectre X" at the Cadence On-line support site URL:
    support.cadence.com/.../ArticleAttachmentPortal
    Page 15 and 16 detail how to use the preset override feature with Spectre X. I put together an example of how to set the relevant GUI and the subsequent relevant sections of the netlist and spectre.out file showing the use of Spectre X with the preset override feature set to "method" and the method set to "gear2only" in the hope it might help. I've placed the note at URL:
    www.dropbox.com/.../spectre_x_tran_algorithm_gear2only_sml_081222.pdf
    I hope this helps sjwprcker!
    Shawn
  • sjwprcker
    sjwprcker over 4 years ago in reply to ShawnLogan
    Hi Shawn,
    Thanks for your feedback, it works.
    Can you give more info why gear2only is proposed here, and why not other integration methods? Before SpectreX, we generally use trapgear2 to avoid trapezoidal ringing..., any rational for gear2only?
    BR
    ShawnLogan over 4 years ago in reply to sjwprcker
    Dear sjwprcker,
    I was happy to red ti worked for you - great!
    I cannot speak for Cadence's proposal specifically with respect to Spectre X, but the second order gear integration method (also called Backward Differentiation formulae or BDF, and actually proposed by Dr. C. W. Gear in 1971) is known for its stability (i.e., immunity from the numerical ringing seen in trapezoidal algorithms). Hence, in many transient simulations, it is my choice among integration algorithms.
    As shown in the Spectre reference manual, the "trapgear2" choice for an integration algorithm does not preclude the use of a trapezoidal algorithm, but allows the simulator to choose between Backward-euler, Trapezoidal, and Second-Order Gear  as shown at the On-line support URL:
    support.cadence.com/.../techpubDocViewerPage
    and included below for your convenience. Hence, its choice does not enforce the use of a second-oder gear algorithm exclusively.
    Does this help at all sjwprcker?
    Shawn
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to sjwprcker
    There is some additional background information at https://support.cadence.com/apex/techpubDocViewerPage?path=spectreRFTheory/spectreRFTheory20.1/chap3.html#pgfId-1015935 . One point to be aware of is the fact that Gear's backward difference method exhibits artificial numerical damping.
  • sjwprcker
    Hi Shawn,
    Your answer is quite clear, thanks a lot!
  • sjwprcker
    sjwprcker over 4 years ago in reply to Frank Wiedmann
    Hi Frank,
    Thanks for your comments, they are also useful information.
