  3. How to plot temperature vs time in Viva?
  • Views 12545
StephanWeber
StephanWeber over 4 years ago
I am using veriloga and cds_set_temperature to make T varying vs time. I could plot the internal variable to get T = f(t), but I wonder if there is a more direct way? I am using icavd 20.1.500.22 and spectre 21.1.0.246.isr4.
Bye Stephan
    ShawnLogan over 4 years ago
    Dear Stephan,
    My thought may be obvious to you, and if it is, please accept my apology in advance!
    However, the conventional method to provide the temperature as an output for plotting in ViVA involves either including a file containing the following:
    save temp
    and then including this file in the netlist. Alternately, you may accomplish the same thing graphically by:
    1. Place an unconnected wire in your schematic and set its name to "temp"
    2. Add node "temp" as an output to be saved
    Either of these will save the temperature as an output that can be plotted. As an example, I used the latter methodology and performed a transient simulation where I used temp as a dynamic parameter to vary its value with time. The example and setup instructions are contained in the note at URL:
    www.dropbox.com/.../saving_temp_vs_time_example_081822v1p0.pdf
    I hope this was not obvious to you and, perhaps, provides some insight Stephan!
    Shawn
  • StephanWeber
    StephanWeber over 4 years ago in reply to ShawnLogan
    Looks cool, but is there also a solution for simple AC or DC simulation? I can't see temperature in Results Browser.
    Bye Stephan
    Andrew Beckett over 4 years ago in reply to StephanWeber
    How would that help for AC or DC simulation anyway? The temperature won't change during AC or DC unless you sweep temperature, in which case it's the xval() of any output.
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    Cool hint. In the mean time I made a little veriloga module:
    `include "constants.vams"
    `include "disciplines.vams"
    // may show little glitches, might be a Spectre bug?
    // In DC: showing only Tj from simulator
    // In Tran: Showing dynamic T
    // Test for static Tj simulation: ok
    // Test for Tj as dynamic parameter: not tested
    // Test for Tj set by cds_set_temperature: works basically, but short glitches possible!
    module Tmonitor(t); // in should represent T in Celsius
    input t;
    electrical t;
    real temper=0;
    analog begin
    //@initial_step V(t) <+ $temperature-273.15;
      temper = $temperature-273.15; // function itself is in Kelvin
      V(t) <+ temper;
    end
    endmodule
