  3. Automatic check and save in Assembler/Explorer??
  • Views 3075
StephanWeber
StephanWeber over 4 years ago
I remember doing check & save for the schematics has been partially automized In Virtuoso. So I remember, if it is needed and you forgot it, then after pressing run you got a reminder, and even got got the question if it should be done now for you prior to the simulation run.
However, in my current environment, either Cadence or my company, changed the behavior. Now, I see this if I forget to do check & save: If I press run, it takes 0.1s to observe that something is wrong and that the simulation does not start!
The error message occurs now in CIW only, telling me correctly what to do. This is quite ok, but I wonder, where is this good dialog gone asking the user if check and save should be done???
Can I re-enble the good behavior with dedicated message for C&S operation, instead of the pure erorr message in CIW?
Bye Stephan
    Stephan,
    envSetVal( "adexl.test" "checkForUnsavedViewsUponRun" 'boolean t)
    This is the default, so it's presumably been turned off in your environment (search for checkFor in Options->cdsenv editor in the CIW to check).
  • StephanWeber
    Hi Andrew, thanks for fast response.
    The strange thing is that this setting should be already in place. I got this in cdsenv:
    adexl.test    checkForUnsavedViewsUponRun    boolean    t
    Are there more variables controlling this? I am using Virtuoso icavd 20.1.500.222.
    Bye Stephan
    Andrew Beckett over 4 years ago in reply to StephanWeber
    Stephan,
    Are you sure that's not being overridden somewhere (say in a .cdsinit somewhere) - does it still have t if you search in Options->Cdsenv Editor? It might be t in the .cdsenv file but overridden in a SKILL envSetVal call somewhere.
    I don't think there are other variables controlling this.
