  3. Characterizing Transmission gate based cells for liberty...
  • Views 10890
Characterizing Transmission gate based cells for liberty file
NKFET
NKFET over 4 years ago
I want to characterize a pass-transistor or transmission-gate-based standard cell (e.g., MUX or XOR). As the pull-up and pull-down networks are not connected to Vdd and Gnd, like standard CMOS, how can power consumption be measured? Can the Cadence Liberate manage it?
  • Guangjun Cao
    Guangjun Cao over 4 years ago
    Have you already tried to characterized the cells with Liberate? to understand how the power is calculated by Liberate, you can use 'set_var power_info 1'. Liberate will save the expressions/results in a file under the deck area defined by extsim_deck_dir. Filename can be defined with power_info_filename. you may also save the decks using 'set_var extsim_save_passed deck'.
    Liberate only calculates power consumtion for the PG pins that are defined as pins of the cells. power due to input/load can be deducted during .lib generation. this is controlled by pin_based_leakage/power,  power_subtract_* and other power-related settings.
    Guangjun
