  3. Can I preset the width and length of simulator log file...
  • Views 10784
Can I preset the width and length of simulator log file viewer?
StephanWeber
StephanWeber over 4 years ago
when inspecting spectre log, I usually need to 1st make the window larger. Isn't there a way to get a larger window by default?
Bye Stephan
    envSetVal("spectre.envOpts" "autoDisplayBBox" 'string "0 0 800 1000")
    Search for autoDisplayBBox in the documentation.
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    There's an article on this: How to set the default window size for viewing spectre, xrun and irun log files and netlist in ADE L and XL
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for fast response. I applied this setting in CIW, but I see no impact on size of spectre log (and also not on netlist window too). Is this really taken into account for Assembler in 20.1.500.22?
    Bye Stephan
    Andrew Beckett over 4 years ago in reply to StephanWeber
    Hi Stephan,
    You need to set it before you open ADE Assembler. It has no effect if you do it after starting Assembler. Did you do that?
  • StephanWeber
    Thanks, with ADE restart it works fine!
