  3. How to get rid of Weight column for Results tab in ADE?
  • Subscribers 136
  • Views 12345
StephanWeber
StephanWeber over 4 years ago
I found this env variable may help:
envSetVal( "adexl.gui" "detailViewShowDefault" 'string "\"Test\" \"Spec/Weight\" \"Min/Max\" \"Corners\" \"Waveform Expressions\" \"Post Run Results\" \"Device Checks\" \"User-Defined Columns\"")
However, I see that Spec and Weight is combined, and I want to keep Spec as this is important for me.
Ultimately, I need the Weight only for optimizations, else never.
How to achieve this?
Bye Stephan
  • mschw
    mschw over 4 years ago
    Dear Stephan,
    I don't know if it can be done in ADE-XL, but if you switch to ADE Assembler you will be able to enable/disable Spec and Weight independently of each other with
    envSetVal("maestro.assembler" "defaultOutputColumns" 'string "\"Test\" \"Name\" \"Type\" \"Details\" \"EvalType\" \"Plot\" \"Save\" \"Spec\" \"Weight\" \"Units\" \"Digits\" \"Notation\" \"Suffix\"")
    Kind regards
    Matthias
  • StephanWeber
    StephanWeber over 4 years ago in reply to mschw
    Thanks Matthias, but I need it for the Results tab, not for the Output setup table. I want a compact results table.
    Andrew Beckett over 4 years ago in reply to StephanWeber
    Stephan,
    There's an enhancement request for this, CCR 1963019, filed by you in a previous life... (with a number of more recent duplicates). It's not been planned yet.
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    Super many thanks Andrew!
    It looks a nice to have thing, BUT zooming and scrolling just because some screen area is "wasted" is required very often and bothering many designers.
    Is there also a plan to allow hiding of columns just by pressing right mouse button and select "Hide" ? Could use this as workaround.
    Bye Stephan
    I'm not aware of any intention to add a second mechanism to hide columns - it would probably get rather complicated to have two competing mechanisms (there's already a menu to do this via the table icon next to the double-gear icon in the toolbar above the Results).
