  3. Power and delay of digital circuits using cadence
  • Subscribers 136
  • Views 14948
Aswathyn
Aswathyn over 4 years ago
Sir,
I have some doubts. please clarify. I want to calculate various power and delay of digital circuits
1. How to calculate static power?
Suppose I use DPTL C2MOS NAND/AND logic. here A, B and Clock signal is there. for calculating static power do I make all A,B and Clock signal to 0Vdc and and annotate the current and multiply with Vdd.
If I make A,B and clock to 1V Vdc, it gives another power. so do I add both or which is actual static power?
2. for calculating total power make A, B, Clock to pulse and and multiply Vdd and current. Is it correct?
3. how can we choose clock frequency and pulse period of A and B for delay calculation. Is there any rule to set that pulse period and run time of simulation etc.
    ShawnLogan over 4 years ago in reply to iq79 +1
    Dear Aswathyn, I've taken a stab at providing some thoughts on each of your questions below. Your second question is related to your third and hence information regarding my response to it is implicitly…
  • iq79
    iq79 over 4 years ago
    Good Sir,
    1. I'm not an expert in DPTL-C2MOS, but I'm sure that the static power dissipation depends on the input combination. For NAND/AND it is easy to simulate all input pairs. Maybe then you could pick the worst one as your static power.
    2. You can add 'saveOptions options pwr=all' to the end of your spectre inputfile or if you use  ADE: Outputs->Save all ->Select power signals to ouput(pwr) and check 'all'.
    You find the power graphs in Viva in Windows->Assistants->Browser and plot them and import them in the calculator and compute the average and so on ..
    Kind Regards,
    Iqbal
    Dear Aswathyn,
    I've taken a stab at providing some thoughts on each of your questions below. Your second question is related to your third and hence information regarding my response to it is implicitly included.
    I've placed a note with my comments and simulation examples at URL:
    https://www.dropbox.com/s/jvihxil18xl6sh1/static_power_tpd_meas_comb_sequential_logic_082822v1p0.pdf?dl=0
    I hope this provides some thoughts on what paths you might consider for both your static power estimate and determining relevant and accurate propagation delay times.
    Shawn
  • Aswathyn
    Aswathyn over 4 years ago in reply to iq79
    Sir, while calculating power suppose if i give input A and B 0V, then what about the clock is it set to IV(enabled) or 0v
    ShawnLogan over 4 years ago in reply to Aswathyn
    Dear Aswathyn,
    As with all the other combinatorial inputs to your circuit, the static power needs to be computed with the clock in each valid state. This is especially important in clocked logic as when the clock is in one state, some of the nodes can assume a high-impedance state. If you are not using "keeper" devices to hold the state of dynamic nodes, their voltages will vary with time and a transient simulation to estimate static power is advised.
    I hope I understood your question Aswathyn and this helps you a bit!
    Shawn
  • Aswathyn
    Aswathyn over 4 years ago in reply to ShawnLogan
    thankyou sir for your reply. one more doubt
    while calculating delay in the case of nand gates we need to consider either A or B and the out for calculation or both  A and B with respect to out.
